- 5 Aug 2006
- Northern Ireland
hi,
not sure what the k and the kf means?
hi,
Would that make the KF range better for overclocking then the K range ?The F range does not have onboard GPU.
No not that i know off os should install fineoh right, thanks.
does it matter if you buy with onboard or graphics or not if you have a gpu! or does it cause issues when installing OS?
oh right, thanks.
