Temp Increase
17 Feb 2009
When I first fitted my AIO cooler it would idle about 33c and under full load Cinebench it would be 67c
It's now 36c idle and 72c full load.
I did initially turn the fans down a bit, should I increase them a bit or not ?
R5 3600 with a Kraken NZXT cooler.
Just not sure why the CPU used to run cooler than now
Thanks
Edit:
it looks as though there could be a fair bit of usage even though it's idle
72c full load is fine. If you're happier with the quieter fans just leave it :)
Silly me. I didn't have NZXT Cam open.
I opened NZXT cam and the temps have dropped down a bit now to 68c under full load.
I was just concerned that my temps had increased without explanation
