I completed my new build system start of feb when I managed to obtain an RTX3080 FE, full spec:
CPU: 5900x
Cooler: Dark Rock 4 Pro
Mobo: MSI X570 Tommahawk
RAM: Crucail Ballistix Red RGB 2x 16GB 3600 CL16
SSD: Samsung 970 Evo Plus 1TB
PSU: Corsair RM750i
Case: Fractal Design Define 7 Compact (w/ 4x 140 & 1x120 Fans)
GPU: nVidia RTX3080 Founders Edition (connected using Corsair 12-pin cable)
Since last Wednesday I have been having random black-screen reboots. I had updated to latest nvidia drivers earlier that day.
The crashes usually happen in-game, and usually within a few seconds of the game full loading. However they have also occurred at desktop just web browsing.
Here is what I have tried so far:
1.) reverted driver to previous version (using device manager revert button)
2.) Clean-install of the latest drivers
3.) Disabled GeForce experience overlay and updated to the latest version.
4.) Ran the card at stock clocks instead of its usual undervolt of 850mv @ 1850Mhz
5.) To rule out the CPU, ran stock. Instead of the usual -30 curve. (Ran Prime95 for 4hrs at usual undervolt to confirm stable)
6.) To rule out RAM, ran at stock instead of XMP. (Ran Memtest @ stock & XMP settings. 0 errors after 5hrs+)
7.) Confirmed all physical cables secure. Reseat card securely in PCIe slot and ensured good fit.
So far none of these tests or fixes have worked. Most annoyingly I cant reliably cause the issue. Sunday I had 3 black screen reboots while just using Firefox (trying to complete the census of all things!)
The day before I had 2 black screen reboots trying to play Hitman 2, then was able to play fine for 2hrs+ on the third attempt.
Day before I attempted to run Prime95+Furmark. On first attempt, after less than 1m of both running system reboots. When it came back up, it ran fan with both CPU & GPU @ 100% load for over 30 minutes.
On Sunday I ran 5hrs+ worth of Memtest86 (both at stock & XMP) to confirm RAM is 100%, followed by 4hrs of Prime95 with CPU at its usual -30 undervolt. (So system online for 9hrs+) Then I browsed the web for a bit, before going to test FurMark one more time... and again black screen reboot within 1m~
All this leads me to believe the issue is the RTX3080 FE. I know some people will point fingers at the PSU, but if the PSU was the issue id be expecting it to crash reliably at very high power loads.
I do have a near 10-year old HX750 I could test too, but would rather avoid doing so, as that thing is long past warranty period.
As these are black-screen-reboots, I get nothing in event viewer. Just a "event id 41 task 63" indicating that the previous shutdown was not clean. Nothing to indicate what caused the issue.
I disabled auto-restart in Windows, but it still does it anyway.
I am at my wits end as to what the issue could be. The system ran 100% reliably for nearly 1.5 months. Since Wednesday I barely trust it...
My next test is going to be a clean install of Windows on a different SSD, install just the bare minimum and see if I get crashes the same way.
Appreciate any tips of pointers any of you guys may have!
CPU: 5900x
PSU: Corsair RM750i
