2 mining rigs. Each rig consists of 13 radeon RX 5700 xt 8GB ETH 700 MH/s GPU cards.
I don’t think so. Aren’t they stacked so there’s two rows per rig?Theres 14 cards there 7 in each rig
How profitable is this?
No offense to miners, but really hope governments find a way to tax mining into oblivion. Lol.
There are 21 cards though not 14. Its hard to see how they are connected to a computer.
I think there are 14 in each of the two rigs there, double-decked.
For connection, look up "PCIe extender 1x" on a popular site, effectively there are tiny 1x PCBs that can be connected via something like a USB cable to 1x connectors on a motherboard like the one above.
I'd think it was ingenious if I didn't also think cryptocurrency was a dumbass waste of time and resources, and a massive backwards step for global energy wastage...
Mining is heavy compute but very low data throughput.
Here's an image of the board mentioned above, those little PCIE slots are all x4, so you can have 4x more of them than on normal boards. Such usually isn't recommended for a GPU, but is completely fine for mining as the algorithms primarily just leverage the compute, they don't transfer much data to and from the GRAM.
Wouldn't that board explode if you tried to draw power from all those little slots? Does it prevent the graphics cards using board power?
GPUs have power cables directly coming from the PSU, the risers also have a 6 pin or molex or sata power input. So, it won't draw "a lot" of power and kill the mobo.Wouldn't that board explode if you tried to draw power from all those little slots? Does it prevent the graphics cards using board power?
