Some of us have never used a bot to buy a card, its fairly impossible to buy a nvidia fe at the moment without a bot. The only time was when 3090 stayed in stock for a few hours sometime back
I bought mine without a bot. Just checked constantly
You literally need to be sitting by your computer waiting for it drop now days.
Then you got lucky, i only got a 3070 on the off chance as i was looking a 3080. The german nvidia store had drops for the 3080\70\60ti\90 yesterday, the 3080 was gone literally as soon as the alert popped up. The rest followed soon after. If you're after a 3080fe then you have more or less seconds to try and grab one as thats the card it seems most are after.
Be interesting to see what the uk retailer for fe's does when these finally appear, will owners of the original 3 series be able to buy one or are they still blocked as they own a previous card?
And even then its pure chance if you get through all the hoops in time. Filling in the captcha before the appear so you can skip that step only seems to last a short while. More than likely by the time you get to the checkout the cards already gone.
Stick an RX 480 in a basic mid tower case with 1-2 case fans, it's probably gonna be fine for 5-10+ years. Stick an RTX 3090 in the same case and you might not be ok.![]()
anybody got a RRP on the new FE ti cards? thanks!
This isn't really true.
I thnk the retailer selling these have some of the best bot prevention out of all the guys selling cards.
You need something to alert you to when they are in stock, but there are plenty of twitter accounts that'll do that. Actually purchasing one needs to be manual and it's not too difficult so long as you're quick.
