- 2 Feb 2021
Just putting this out there to see if anyone else feel the same.
I've always been a bit of a EKWB fan boy when it comes to water cooling, I have their D5 pump, coolstream radiator, cpu/gpu plates (3090FE on back order), and about 30 fitting pieces for hardline 16mm fittings.
Until now I have purchased directly from EKWB, since they usually had the best price and most variety, however since Brexit I've had some bad experiences with customs, as thus I have been turning to OCUK to supply EKWB parts.
Recently upgrading a custom distro board I have needed an extra 16 fittings, and there was no stock with the colour I wanted, so in a pinch I turned to eBay and found some Barrow hardline fittings, fully intend to replace them after EKWB come back to stock. However after using them I've found the both build quality and seal quality is superior to the EKWB standard fittings.
I've been working with acrylic tube for a while and it is always hard to get the perfect smooth edge and I've always struggled to get a perfect seal with EKWB, with Barrow fittings the hold is rock solid with 3 layers of o-rings, and feels very re-assuring.
Given the price difference between Barrow and EKWB I was pleasantly surprised, and are now considering swapping the remainder of my EKWB fittings to Barrow. Certainly it has improved my impression of them, if anyone else is looking for hardline fittings I would recommend Barrow over EKWB.
