Using a single Dual 8+8 Pin PCI-E Cable?
30 Nov 2005
London
I own a Corsair RM650x PSU and am upgrading my old 1070TI for an 6700XT.
The new GPU requires two 8-pin PCI Express Power connectors
The Corsair RM650x includes a PCI Express Power cable with two 8-pins on it (6+2 and 6+2).
Is it OK to use this or should I really be using a 2nd completely separate cable?
It’s generally recommended to use two cables, but I’ve used plenty of cards in the past with a single cable with 2x 8 pin connectors including a RX 6800.
For a 6700XT I really don’t think you will have anything to worry about, especially given the 650x is a solid PSU.
Using two cables is one of those Urban legends I think.
It's obvious why it might be better, but I've never actually heard of it ever being a problem in anyone's build.
doesnt the 650x have 2 gpu cable slots? deffo use these. i had all kinds of space invader icons on screen with 2080 when using the daisy chain cable you mention
Vega 64 and some 5700XT builds were plagued with issues because of using a single cable. Quite a few threads on these very forums too.
