Hey all,
Recently posted about my new loop and had great advice. I'm now wanting to make a slight tweak to the loop to make it really complete and would like some recommendations.
The current res is sort of haphazardly screwed in via one screw to the PSU shroud grating which doesn't feel like how I'd like to be for a long period. Can see it just behind the GPU.
I'd quite like to mount a cylindrical res to the front 360mm radiator and I'm looking for some advice on:
-Reservoir
-Mounting hardware (2x120mm space available as PSU shroud blocks bottom fan)
-Pump (unless new res can accommodate my dc-lt 2600?)
Greatly appreciate any help/advice as I'm a bit stuck. Is this where you would put the res if it were your system?
Edit: This is what I had in mind:
ThermalTake Pacific PR22-DDC Reservoir/Pump Combo
-Reservoir
