Can I have a hdd without a drive cage
Sata ssd can be left lying anywhere in the case, have done it in the past cause i was to cheap to buy an adapter to slot it in a 3.5" bay.
You may also find that your chassis has some key hole fittings and rubber dampeners that you can use to fit it without a cage. for instance the Fractal Define C has a cage but it also has some key fittings under the cage in case you want to remove the cage to fit a watercooler.
If you can find somewhere to screw it into then yes. Elsewise if you want to go getto you can use double sided tape (or something similar).
Don't just leave it fippin and flopping around unattached to the case though. One day you'll pick the PC up or move it and that drive will case damage to the delicate components.
