*** New Raijintek Pan Series Cases ***
1 Dec 2015
True didn't even think of a 240 and 360, this case looks like it could be fun to play around with
Just sent Raijintek your idea along with combo of 240+360. I've mentioned to them I wanted to use their distro plate above the PSU section... should have about 4mm clearance as their plates are 34mm thick with SFX being 63.5 in height .
@orbitalwalsh - When you get it, could you measure the height of the CPU cooler capability?
I'm wondering if a Alphacool Eisberg reservoir cooler will fit or whether or not it'll be too tall. Can't see any specs on the manual or website!
The Chassis height is 110mm . I'm guessing the motherboard standoffs are standard 10mm with Eisbaer being 60mm tall .. should work . Alphacool sent me their low profile server fittings, which are dam handy !
https://imgur.com/hmgaOO9
About 20mm in height, full rotary
image I was sent from Rep
https://imgur.com/a/8TWcbJ0
3 Feb 2009
Case is coming tomorrow ! Via faster company Caseking Germany... But £47 import charges !!!! Brexit sucks but UPS charging extra on top really is a bug bear !
If only the 2 companies were connected somehow... Regardless, pretty sure they still count as a competitor and probably shouldn't be named here.
1 Dec 2015
Raijintek said I could have waiting for Caseking to ship over to OCUK but said I'd rather get it sooner to get up snaps etc . Seems UK reviewers also had to pay . Just the fact it's only UPS that charge admin fees ontop !
1 Dec 2015
Box is big....
http://imgur.com/a/RIH8bmS
RIH8bmS
RIH8bmS
1 Dec 2015
Will get on and do a build log... Some reason Imgur has changed so can't embed via phone for images so here's album links
So far
  • Full fat ATX PSU would fit (need to mod slightly ) but has limitations
  • Radiators larger then 27mm stated by Raijintek , but would need 90 degree fittings etc
  • ATX does fit fine without mods , and PCIe actually lines up for a solid PCIe circuit board
  • Using ITX, is possible to have dual rad set up using 1.5 slot waterblock and 20/25mm rad with slim fan combo
  • 480 fits in across the back - again needs to be slim is using standard ITX , so does 240+360 combo
  • 120mm fits in behind SFX housing just fine
http://imgur.com/a/zzevrjX http://imgur.com/a/zzevrjX
http://imgur.com/a/owuuPY7
http://imgur.com/a/az2E95M
1 Dec 2015
How is the thermal performance on these cases?
In theory, should be good.. if you set it up in positive and exhausting out the top of the case ! Not how they have shown in media with AIO drawing air from the top and exhausting out the bitten, as the GPU would then suck that air in !
Unfortunately... I got caught short.. cables not long enough so grab some extensions !
And also, for standard ITX build, wanting to add second rad with GPU water block. I lined up a two slot GPU ontop of 20mm rad with 15mm can, and you'd have clear space ! Most likely could use 27/30mm thick rad
1 Dec 2015
not stated in video! possible cable extension for EPS and 24pin, specially if you have silverstone SFX!
also, mount an AIO so its pulling in air from the bottom of the case, not the top like above
will be doing my own hopefully start of next week
