- 23 Nov 2009
- North Leicestershire
So i've picked up a couple of fittings for my first hard tube build after using soft tube for nearly 10 years, one thing i don't like is the locking ring on the 2 i got which seems purely aesthetic. it don't lock the tube in place and the tube can be removed ludicrously easily. i just feel any shift in the case will end up breaking the seal. can anyone recommend any fittings that have a better bite? I've seen some barrow ones that have a locking mechanism but apparently they are crazy hard to fit correctly. I just want something that maybe has a compression seal on the locking ring which bites the tube to hold it in place tighter.
thanks in advance!
thanks in advance!
