WiFi adapter card upgrade for Ryzen chipset laptop.
29 Sep 2010
Hi all,
Recently picked up one of these https://www.overclockers.co.uk/asus...z-ryzen-r7-4800h-gaming-laptop-lt-2cc-as.html
Runs great, one issue though is the WiFi coverage is absolute junk, can't game in rooms other than where the router is based, even when in that room a speed test shows 60mb when I can run the same test on my phone and get 230mb/s, I've tried different drivers etc and the connection is just still flaky / poor. Turned off power saving bits etc with it being a laptop, same issue prevails. If i move into the next room it drops to as low as 15mb/s, upstairs is a no go.
Anyone have any recommendations for a WiFi (6 maybe?) card to replace the existing one, most of what I can find are for Intel based chip sets :(
Thanks
Is it m2, and why would it not work due to being an intel WIFI/BT card?
Some of the AMD Mobos have that dread buggy Intel 2.5Gb/s NIC in them.
Would you like WIFI6E and BT5.2 for like £20-25?
Intel AX210
Intel AX210
I'm just going by most product pages saying Intel chipset only, if thats not the case, great :D
Yeah it is m2
The older model the AX200 was for any device but the AX201 needed an Intel CPU of certain models for 2 functions it had (I would need refresh my memory and read up).
The newer AX210 is any device and I assume a AX211 or such will also appear.
You could just buy the older AX200 and have WIFI6ax and BT5.0 if you want to save a few £ and easier to find, do not buy the AX201 for reason above.
Great, found the ax200 for a dubious 17 quid but fulfilled by that rainforest place and reviews saying seems a genuine product, so taken a punt if not I'll get the AX210.
Thanks very much for your help will report back when it's installed tomorrow :D
I picked up one of these cheap AX200's for my Tuf A15 also after speaking to you and my speeds have went from around 60mbps to a solid 160mbps, (i think my old virgin router is having a heart attack keeping up :) )
At first i thought it wasn't any better than the realtek one but it turned out steam had started a 18gb update for street fighter 5 which it did at a constant 20mb so i'm very happy now :)
