You guys ready for picture overload. It's been a busy weekend!
First we had this raised bed down the side of the house, it was nice but we were never a fan of the stone wall (especially where i'd rebuilt part of it very badly). We also wanted somewhere to stick the bins as currently they're right next to the back door on the patio.
So this
Became
After i took the wall down, i took a man break. It was good Friday after all
Then rebuilt a sleeper wall and used decking on the flooring. We were going to use some fake grass offcuts, but i decided this would be better. £60 to floor two small areas feels annoying though!
(Nb i have pointed up the bits around the edges of flag/decking
Then i moved onto my desk. Someone of you may remember i got some free scaffolding boards. Just sanded them back and jointed them up. It's not perfect but it'll do as didn't want to spend too much time on things. Was hoping because it was only short (around 110cm), it'd be ok just using some 3x2 batons along each wall, but the right edge was pretty unstable so i added a support at the end. Annoyingly the last offcut bit of scaffolding board was 3cm too short so i used some 6x3 i had lying around to give a nice chunky look. Can't decide whether to oil the leg or paint it given the grain etc will be completely different.
I've also made the desk slightly high which is annoying as if i'd done it lower the scaffolding offcut would've been fine. However hopefully it stops me slouching! Only issue i'm finding as i type now is the varnish has lifted the grain in a few places so need to sand that back lightly.
Also bought a large mouse pad.
Then to go on the bit of decking to the left of the raised bed down the side of the house, my wife wanted an area to dry the dogs after showering them (we have an old belfast sink with hot water feed down that side of the house), previously she used the outdoor table, but our dogs shed like no other animal on earth so the tables always full of dog hairs, she was looking at some rubber mats to avoid the paws slipping. I had an old bit of birch ply lying around so i've routed some channels into the top. Will have to see how it goes, otherwise i may mix some sand and paint to give a grippy top feel.
Ignore the awful paint job. It's some really crap fence paint we bought ages ago and i just needed something to protect it.
Then set about extending my to do list. We have an outdoor wall which has the start of an oak tree growing inbetween the bricks. I took the top stones off and realised the roots go deeper into the wall than i realised. Going to pull out as much as i can one night this week and then drill the remaining roots. I've taken down the top row of bricks on one side to get a better attack. So will need to rebuild that at some point too. The bricks are really old and crumbly so need to look into how weak a mortar mix i should used.
Also saw a bit of felt flapping around ontop of the shed. One of my other jobs is the change the roof as it leaks quite badly in some areas, but didn't realise it was this bad. Lots of the wood is absolutely rotten.
Also our garden goes to a weird point. I'd never realised before but because the shed is square we have a hidden triangle. From climbing over the shed i found this little lost bit, with a lovely looked (Acer?) tree. Bizarely the shed condition looks almost new on this back section, yet the bits we see that'd been painted are all ruined. Shows how exposed it is.
Also went out to buy various bits of wood. We tried sitting out on Saturday when i'd finished with the fire pit, but it was so windy we retreated inside. Have decided to build a wooden framed windbreaker using that bamboo screening stuff. The plan is to have 2 sections with a hinge and then on castors. That should mean it's stable enough and we can move it around/angle it however we want.
