One thing that hasn’t been mentioned with the Ford Ranger, on some the engine oil pump has lost prime or failed and then its curtains for the engine unless you get lucky and stop it quick enough. Don’t think it affects the new models but have heard of it on models of the age you are looking at. I believe Ford have a service advisory in that when the oil has been dropped out servicing then new oil needs to be poured in within so many minutes. This is to prevent the oil pump from draining and losing prime. I don’t have a Ranger but other than that it seems a good enough pickup. Can have electric problems too. I have an Isuzu and they can suffer from DPF problems but other wise ok if agricultural. Amoraks are expensive but sound. No pickup seem perfect![]()
It pulls 2.2 ton so the trailer is roughly 850 kg and two horses at roughly 550kg each average gives us 250 kg to play with which is fine for two people and their tack.After a lot of looking around, sitting in pickups and looking underneath them we decided to get an R-line VW Tiguan 4 motionIt pulls 2.2 ton so the trailer is roughly 850 kg and two horses at roughly 550kg each average gives us 250 kg to play with which is fine for two people and their tack.
