Starting from nothing. Smart home build.
Caporegime
13 Jan 2010
Llaneirwg
I was wondering if any of you guys have any useful smart home tips for the most seemless setup?
Any pitfalls and what not to get. Minimising different brands if that matters.
I do not even have amazon alexa/Google home.
Journey is going to start with smart lighting, plugs and most likely tado.
Honestly I don't k ow the scope, obviously you can turn lights on and off, control room temps.
However, I'm not sure if you can say 'alexa, living room temperature 20c' with tado, or if you talk to a tado app etc.
Any starting tips?
This is 100 percent a blank slate! Not even the TV is smart.
Yes you can, we control both Tado and Lifx bulbs with our Alexa, or their individual apps.
You can make custom routines to, we have "Alex, light em up!" to turn on all the lights in the house, and "Alexa, disco inferno" which will max temp all our radiators.
From my experience, do research in what brand you'd like to go with because different devices work differently with different brands for example I went google/nest for everything. If I installed my Google nest hello doorbell and had amazon echos around the house when the doorbell goes I'd have to say "alexa who's at the door" for the doorbell to show on the echo. Where as I have Google hubs around the house when the doorbell goes it automatically brings up a picture of the front door and if you have the Google aware sub it'll say " David is at the front door" everything is worked through the nest app as well, I can tell the hubs the change the room temperature (nest thermostat) or open the app to see all my devices. Heating,cameras, doorbells, even my TV's are connected via smart things.
Between Google home app and nest app thats the only 2 places I need to go to to control pretty much everything in my house.
And the price of your smart home will grow and grow its a money pit:eek:
Think about smart light switches rather than smart light bulbs. Much cheaper, they don't have a life expectancy like bulbs, super easy to fit
I started with Alexa but ended up moving to Google Home as it is just a slicker, better ecosphere (unfortunately a bit more expensive as well)
At this early stage of smart homes, the only "seamless / one-device type control" setups are very expensive. Most of the big named brands work fairly well together, but things can start getting expensive.
As you're starting from a blank slate, i would first think what it is that would make your life easier at home that a smart device could provide help with.
Having a few lightbulbs that you can switch on from your app isn't a "smart home". You've been able to control the function of a lightbulb remotely for at least the last 10-20 years (timers or remote switches for example).
A couple of examples that i've integrated in my home:
- Door contact sensors/motion sensors in the hallway, so lights come on as soon as i open my front door - no faffing around trying to find a light switch (especially useful if carrying shopping etc)
- Temperature/humidity sensors in each room - will come in useful for when i eventually install smart heating
- Smart blinds - i have mine on a schedule to open/close in the mornings/evenings, could also have them automated to close when you start a film
- Automations on washing machine and dishwasher - i'm a nightmare for putting a wash on and forgetting about it - so i now get an announcement through my smart speakers, and a push notification to say the washing machine has finished - same for the dishwasher
- Smart plugs - for various things i might want to switch on or off at certain times - i envision that eventually electricity tariffs will be charged dynamic rates based on time of day (Agile Octopus), so being able to switch things on/off based on the unit cost of electricity would be a big thing
- Security - smart alarm, contact sensors on doors/windows - this is more useful in the summer where i can quickly glance at a panel and see if we've left any windows open etc.
- Various hardware tracking - helpful to ensure things like disks are running cool, or CPU's aren't overheating
- Other tracking - monitoring upload/download speeds (you could set up an automation to reboot your router in the event of an outage), i also track my DNS stats, so response times and frequency of blocked requests
- Power monitoring - good to see which devices are consuming most of the electric
- Device that tracks soil moisture/temperature/conductivity, so i can get notified if plants need more watering etc
- Media stuff - Plex tracks quite well, can view usage stats etc
I've got various other projects i plan to do this year:
- Sensor on the waterbutt to track the level of water in the tank - i have a backup tank for water storage that's not connected to the guttering, so helpful to know when the main one is running low on water - also helpful for tracking how much it rains
- Irrigation system for greenhouse/garden - using perhaps some sort of moisture probes in plant pots to switch an irrigation system on - there looks to be quite a few of these types of projects
- Heating - with individual TRVs
- Possibly a robovaccum for upstairs (would probably get mauled by the dog if it was downstairs)
- Security cameras - but not cloud based, and would like to add things like facial recognition to it
- Temperature probes that i can stick in the fridge/freezer, so i can get notified if the temperature drops - door accidently not fully closed, or fridge/freezer died etc.
I'm sure there's others on the list.
I wanted to do this historically, the main issue is that the consumer stuff is dodgy privacy wise. If you really want good home automation, atm you have to buy a bunch of sensors and parts from ali-express and stitch it all together in an open platform like home assistant. It's really not easy, so be warned.
Otherwise pick a big name brand like Alexa or Google Home and allow your new big-tech overlords keys to the kingdom.
