NVIDIA RTX Voice Now Officially Supported on Non-RTX Cards
Man of Honour
21 May 2012
Dalek flagship
https://www.techpowerup.com/280626/nvidia-rtx-voice-now-officially-supported-on-non-rtx-cards
I thought this may be worth its own thread as it could effect a lot of people with non RTX cards.
Wonder if this is related to them supposedly looking at resurrecting older Pascal or Turing based lines to try and fill in some of the demand using capacity on older nodes (though news on that front seems to have gone a bit quiet).
Is there a list of gpus at all?
I tried this a few months ago on an Quadro K3100M (was on the latest drivers at the time) and did not work.
It's a really great tool but my only annoyance with it even on a 3090 is if it's enabled it keeps the GPU core locked at its lowest 3D clock which for me is 1350mhz and never let's it drop below that until I stop it. Had the same problem with the 2080 Ti.
Surely they can make it work without boosting the clocks to ridiculous levels.
Not sure why this is suddenly getting posted all over the place this month (not directed at OP I've seen it elsewhere), as non-RTX support was enabled by Nvidia in the standalone RTX Voice app since last year (no mod to the installer files needed).
My initial findings with this app were excellent (completely removed annoying sounds from teammates) but I eventually started to run into difficulties where I'd occasionally end up sounding like a robot / messed up for no apparent reason. When it works, it's really good, just seems a bit temperamental.
Might give it a go in Broadcast now non-RTX is supported to see if that's any different I suppose.
Correct me if I am wrong, this is just noise cancelling post effect that's done through the gfx card?
just cuts out background noise.
good for working from home to cut out dogs\kids\building noises.
I did try it when it first supported non rtx cards but still could not get it to work on my Quadro so removed it
I wondered that too whatever happened to the RTX 2060 re-release and I`m sure there was mention of 1660 and even 1060.
Just given it another try with the Quadro K3100M and still no joy.
On the latest drivers and latest version of RTX Voice but when all setup the MIC does not work but does as soon as I change back to the non RTX mic. Guess this gpu is just to old.
