Was doing some work inside my house and after trying to find studs with a studfinder, magnets and finally tapping nails in to it in intervals...I ended up getting confused as to what I was dealing with. After drilling through a bit the drill jumped and I thought I was at the next bit of plaster but it was too soon....so i drilled a bit more and it jumped again but I thought I was still in the same bit of plaster. I ended up just thinking **** it and promptly drilled all the way through into the next bedroom. lol
To my surprise I found that our internal walls between rooms are what appear to be referred to as laminated plasterboard. They are literally triple layer plasterboard. First layer is about 18mm, then 24mm, then 18mm all stuck together, WITH NO VOID or CAVITY GAP! I assume they are kind of dot and dabbed together as there is a slight tiny gap between each layer where the adhesive must be making up a bit of the gap. By tiny, I mean literally 1-2mm maybe.
Some of them I guess could have timber in...it's hard to tell. On one wall, I put a TV up and thought I was inside a vertical timber stud as it felt solid...but I'm now doubting whether I actually was. I used long wood screws and the TV has not fell down yet.
It brings me to the question of...how do I securely mount a heavy TV if I truly cannot find timber? I saw online that someone found a house like this in the 80s and he said it was basically massive plasterboard sheets nailed to horizontal top and bottom wooden studs which ran literally at the top of the wall by the ceiling, and at the floor behind the skirting, with nothing in between. Someone else said sometimes the middle layer is between the vertical very thin struts, with the outer layers boarded straight over them all the way end to end, so you essentially in some places would have, plasterboard > thin wooden stud > plasterboard all stuck together.
I've had a couple of ideas as to how to mount a TV in this situation:
1: Use the toggle spring plasterboard mounts that spring out behind the plasterboard but since there is no void, basically drill through the first layer with a large ish hole (which the spring toggles require anyway) and then basically somehow carve away the second layer around the hole to leave a void surround the hole big enough to use spring toggles in the normal way. Spring toggles or grip it fixings can easily take a TV weight on plasterboard as I've used them before.
Could be tedious and messy and risk damaging plasterboard.
2: Drill all the way through the wall and use plasterboard spring toggle fixings and cover the other bedrooms toggle fixings with a picture yo. Ghetto. Yeah nah. Probably not wife approved.
3: Just YOLO some great big wood screws or other type of generic screws into the plasterboard going through and into all 3 layers (but not quite through the last one) hoping it will hold. This will be in about 50mm of plasterboard.
4: Same as 3 but with some kind of dedicated super wide big threaded specialist metal wierd plasterboard screw things. I've seen them but not sure if they would work. They leave a threaded section in the middle to wind a bolt into. Will try to find a link.
5: Same as 3 but use a rull plug of some sort which expands inside all three layers. It would be similar to one for use in masonry since there is no void, and would hopefully expand and be strong....but I can just see the plasterboard crumbling as I tighten the screw in.
6: Build out the wall properly extending it with stud framing. Given the room has just been finished and decorated I kind of don't want the upheaval of this. In the other room I have to do this in it's simply not possible either.
Thoughts?
Thoughts?
