They'll be making huge losses on 3090 pre-orders now. Some SKUs seem to sell at retail for £500-800 more than before elsewhere.I thought that 3090s were more available that 3080s For the past couple of Gibbos updates only 3080s were due in. Not a bleat but I wonder why.
Don't think Gibbo is posting for SKUs that aren't backordered so the fact more 3090 queues have cleared is a factor.I thought that 3090s were more available that 3080s For the past couple of Gibbos updates only 3080s were due in. Not a bleat but I wonder why.
well... it wouldn't fit because the card is so enormous its long cooler touches parts of my case if it's directly in the slot
Yeah you shoulda whipped the mobo etc out of the case tbh and tested it that way, but at least the card is fine now![]()
You're totally right but that wouldn't have been easy to be honest. The PSU is in the basement of the case with a light box above it, with tubes drilled through it. Like just to get that out to attach to the Mobo haha then undoing all the water stuff, getting an air cooler for the CPU which I don't have currently. Like we're talking 2 days to test it outside the case and dismantling everything.
But really can you blame me for thinking it was the card? GTX 1080 Ti worked perfectly with all three risers and an AMD HD something I had also worked fine. And the RTX 3090 itself worked fine for 48 hours etc it just seemed so unlikely to be anything but the card.
The frustrating thing is, the card is literally 2-3mm too long to fit in the slot directly. This is how close we're talking, it's just huge.
On the bright side I didn't re-enter the queue and snap up a second one that you guys should be receiving!
I would have probably done the same lol. My mini ITX case is such a pain that I really cant be bothered to upgrade it to any new spec for my daughter once i have my new build lol
Did see on YT Kyle from BitWit was having no end of trouble with his 6900XT and went through all of the riser cable checks ended up being some cable mod cables lol
Whats so special about that version?£2600, good lord.
That was just a bad joke sorry. I think the guys that does the stuff is on holiday.Yes we know that but it is not this weekit was only a question.
