Hi All
I have a problem with my PC, i'll try and brief, but i have lots of detail:
Upgraded the PC around the start of Feb. All was running perfectly for two months, used most evenings (by far the most use a PC of mine has ever had) until 2nd April, when the PC randomly restarted while playing Warzone. I had been playing for approx 20 minutes. Then it did it again 10 minutes later.
Prime 95 seemed to all work fine. ran a GPU test "Unigine Superpostion" PC restarted as it started. I feared the worst - GPU issue. Updated the Nvidia drivers. All seemed well, superposition ran, warzone ran. Warzone ran even with prime95 running in the background (forgot to stop it).
All was well until 7th April.. after 1.5 hours play, PC restarted again. Ran unigine superposition again, it ran fine in various modes. Back into warzone, instant restart when the match started. Went to bed i think.
8th April:
Ran furmark - fine
Ran memtest - 2 passes, no issues
Ran prime 95 for a bit - no issues
I didnt run these for very long as i didnt have that much time as i wanted to get windows rebuilt and warzone downloading before the kids got back home. i ran them enough to get the temps up a to about where they seemed to top out.
Updated mobo BIOS, checked ASUS GPU BIOS (tool said no update required), Reinstalled Windows, installed chipset driver from MSI website and Nvidia driver, ran the windows updates. installed Warzone. All was fine gaming that evening.
i didnt play 9th or 10th.
11th April (last night) played, 1 hr 45 mins all fine, then it restarts again, i rebooted, restarts as the match starts.
it was pretty late already, but i tried a few things and it seemed to get worse and worse to the point that it'll load to the windows password screen, i type the password, hit enter - restart.
Sometimes i got no display at all. Although once i plugged the monitor in via HDMI (it doesnt show the splay screen/bios etc over displayport, which is awkward enough) it seemed to be booting reliably, but would restart when asked to do pretty much anything. By this point, the lid was off the case and everything was cold to the touch.
i ran with only one ram stick, then the other, no difference.
Specs and date purchased:
Intel i5 10600KF - 3rd Feb 2021
MSI MEG Z490I Unify mini ITX motherboard - 3rd Feb 2021
WD Blue SN550 1TB - 3rd Feb 2021
Crucial MX500 M.2 Sata 500GB - May 2018
Corsair 16GB (2x8) Corsair Vengeance LPX 3200 - April 2017
Asus Strix GTX 1070 - was a warranty replacement that was supplied May 2017
Seasonic X series 750watt PSU - bought used from here in may 2017, but it may have been made in 2013
New monitor - Iiyama Gmaster 2470 - 15th Feb 2021
I can try swapping out the SSD. the nvme is on the back of the motherboard, as MSI (and others) make the 2nd m.2 nmve only, and the 1st m.2 which is under the heatsink, is the only one that will run the sata drive.
I have a 2.5" SSD i can use testing. I have another PSU, its a good one, but its even older (corsair HX620) i have others at work i could probably borrow. they are decent PSUs but only 400w or so.
Ive reached out to a friend who might have some bits i could swap about, but ive not heard back yet.
If its the GPU, i'm out of gaming then. i cant even see how much they are supposed to cost as there is no prices on the websites etc... you lot know the score.
Sorry for the information overload. Any thoughts or ideas?
Thanks
8th April:
Ran furmark - fine
Thanks
