Gas is cheaper per kWh (approx 1/3 -1/4) but you need way more of it so the difference is not that big. When you heat using gas, loads of the heat just escapes around the side of the pan. An induction hob has direct contact and it’s the pan itself that heats up, it’s far more efficient.
Fuel costs to run a hob are insignificant compared to central heating. The fuel bill point isn’t really material.
Oh it most certainly is. I went from all electric cooking to all gas and my bills dropped substantially.
Tbh I'd be wary of anything metal nearby (that's boxed), I suspect phones would die too. Interesting that it boils faster than a kettle, surely you're putting the same energy in?One thing I forgot to mention - Do not put your new digital DAB radio next to a induction hob - It's death cry was worst sound I have ever heardIt's screems lasted ages.
Fairy muff, I thought you were going to explain some magical wayBigger surface area for heating![]()
I've just about binned off gas completely, given it isn't the future. And as much as I appreciate a gas hob, not having any gas supply at all is going to mean gas bottle which I would rather not bother with. ASHP/Solar/Battery/Stove, no gas, well apart from the BBQ/Grill but that is only staying until it falls to bits.
OP, the choice is yours but unless you spend loads of time cooking and it is something you do as a hobby/relaxation, induction is the way forward.![]()
Whilst reading this thread I came to the same conclusion. Enjoy your gas hobs while you can folks, from 2030s onwards gas boilers are being phased out and I expect in the next 20 years or so you'll see the natural gas connections stopped in homes for cleaner / renewable fuels too. It'll be bottled gas if you insist on using it.
Got a source for that?
All that’s been announced is the measures for new homes. As it stands there is no credible proposal to deal with existing domestic and commercial space heating (other than doing a lot of offsetting). There is lots of experiments and testing but nothing that can be deployed at scale in the U.K.
To retrofit a modern property that needs zero remedial works to retain heat is around £8-£10k. That would cover an ASHP, new cylinder and replacing every radiator in the property.
Updating older properties is not trivial at all, heat pumps have a much lower flow temperature which means insulation levels need to be up to modern standards for them to work. That is the challenge.
2035. Yeah ill keep using gas for the foreseeable.
Many many sources, the Government brought forward the legislation in Nov 2020:
https://www.theecoexperts.co.uk/boilers/uk-gas-boiler-ban#:~:text=Are gas boilers being phased out in the UK?,-Yes, they are&text=The UK Government revealed on,net-zero plans for 2050.
https://www.edfenergy.com/heating/advice/uk-boiler-ban
https://www.which.co.uk/news/2020/1...builds-from-2025-what-does-this-mean-for-you/
From 2035, you will not be able to install a conventional gas boiler in any property, new or old.
However, like most things in life, it ultimately boils down to money. The report from the Committee on Climate Change said it would cost £26,300 to install low-carbon heating in an existing house – to install it in a new home, on the other hand, would only cost £4,800.
Yeah they do. Maybe the cheap induction hobs aren't good, but decent ones out class gas all day long.
Mine has 14 point control plus power boost and auto adjusts to pan size. If I've a pan on the boil, the pan responds instantly the moment I turn the zone off/down. Plus I can remove the pan and don't have to worry about the cats or kids burning themselves on the hob. And don't get me started on cleaning gas hobs!
https://eurokera.com/blog/professional-chefs-love-induction-cooking-and-you-should-too/
- typical single induction core ~5"dia means you can get localised heating/burning versus gas(hot gases distribute heat) so need multi-ply very conductive pans to compensate
The days of burning fossil fuels in our homes and cars WILL end in the next decade or two
