MSI And ASUS Releases AGESA 1.2.0.3c Bios for X570/B550 Boards
7 Dec 2010
Leeds
AGESA 1.2.0.3 Patch C (BETA), Is out for ASUS and MSI boards. More info below :-
ASUS
https://wccftech.com/asus-rolls-out...oards-improves-ryzen-5000g-apu-compatibility/
MSI
https://wccftech.com/msi-amd-agesa-1-2-0-3-patch-c-beta-bios-firmware-x570-b550-motherboards/
More boards supported now, REMEMBER TO DOWNLOAD FROM MSI UK SITE THE UPDATE, because the MSI Global site had a corrupt BIOS on it for me with the GODLIKE X570. So if you have an issue I explain how to fix it here :- https://forums.overclockers.co.uk/posts/34899686/.
https://www.reddit.com/r/Amd/commen...gesa_1203b_bios_for_x570b550_boards/?sort=new
MSI Releases AGESA 1.2.0.3b Bios for X570/B550 Boards
MSI releases AGESA 1.2.0.3b BIOS for X570 & B550.
To get the information of bios updating, please follow MSI website. Thank you!
Notes:
- Update to AMD ComboAM4PIV2 1.2.0.3b
X570:
Motherboard Bios
MEG X570 GODLIKE 7C34v1E3(Beta version)
MEG X570 ACE 7C35v1F2(Beta version)
MEG X570 UNIFY 7C35vAA4(Beta version)
Prestige X570 CREATION 7C36v1E2(Beta version)
MPG X570 GAMING PRO CARBON WIFI 7B93v1D2(Beta version)
MPG X570 GAMING EDGE WIFI 7C37v1F1(Beta version)
MPG X570 GAMING PLUS 7C37vAE2(Beta version)
MAG X570 TOMAHAWK WIFI 7C84v172(Beta version)
X570-A PRO 7C37vHE1(Beta version)
B550:
Motherboard Bios
MEG B550 UNIFY 7D13v132(Beta version)
MEG B550 UNIFY-X 7D13vA32(Beta version)
MPG B550 GAMING PLUS 7C56v172(Beta version)
MPG B550 GAMING EDGE WIFI 7C91v172(Beta version)
MPG B550I GAMING EDGE WIFI 7C92v171(Beta version)
MPG B550I GAMING EDGE MAX WIFI 7C92v171(Beta version)
MPG B550 GAMING CARBON WIFI 7C90v172(Beta version)
MAG B550 TOMAHAWK 7C91vA72(Beta version)
MAG B550M MORTAR 7C94v182(Beta version)
MAG B550M MORTAR WIFI 7C94v182(Beta version)
MAG B550 TORPEDO 7C91vH42(Beta version)
MAG B550M BAZOOKA 7C95vA72(Beta version)
MAG B550M VECTOR WIFI 7D14vB52(Beta version)
B550-A PRO 7C56vA72(Beta version)
B550M PRO-VDH WIFI 7C95v282(Beta version)
B550M PRO-VDH 7C95v282(Beta version)
B550M PRO-DASH 7C95v362(Beta version)
B550M-A PRO 7C96v251(Beta version)
B550M PRO 7D14v247D14v252(Beta version)
AGESA 1.2.0.2 BIOS for MSI X570/B550 boards
MSI releases AGESA 1.2.0.2 BIOS for X570 & B550.More BIOS for other X570/B550 motherboards will be released.
Notes:
  1. Update to ComboAM4PIV2 1.2.0.2
  2. Improved USB device compatibility
X570:
Motherboard Bios
MEG X570 Godlike 7C34v1D3(beta)
MEG X570 ACE 7C35.v1E3 (beta)
MEG X570 UNIFY 7C35.vA93 (beta)
MAG X570 TOMAHAWK WIFI 7C84.v163(beta)
PRESTIGE X570 CREATION 7C36.v1D2(beta)
MPG X570 GAMING PRO CARBON WIFI 7B93.v1C3(beta)
MPG X570 GAMING EDGE WIFI 7C37.v1E2(beta)
MPG X570 GAMING PLUS 7C37.vAD2(beta)
X570-A PRO 7C37.vHD4(beta)
4/13 Edit: Add X570 TOMAHAWK WIFI, X570 CREATION.
4/16 Edit: Add X570 GAMING PRO CARBON WIFI, X570 GAMING EDGE WIFI, X570 GAMING PLUS, X570-A PRO.
B550:
Motherboard Bios
MEG B550 UNIFY 7D13.v124 (beta)
MEG B550 UNIFY-X 7D13.vA24 (beta)
MAG B550 TOMAHAWK 7C91.vA64 (beta)
MAG B550M MORTAR WIFI 7C94.v166 (beta)
MAG B550M MORTAR 7C94.v166 (beta)
MPG B550 GAMING PLUS 7C56.v162(beta)
MPG B550 GAMING CARBON WIFI 7C90.v163(beta)
MPG B550I GAMING EDGE WIFI 7C92.v162(beta)
MPG B550I GAMING EDGE MAX WIFI 7C92.v162(beta)
B550-A PRO 7C56.vA65(beta)
B550M PRO-VDH WIFI 7C95.v272(beta)
MAG B550M BAZOOKA 7C95.vA62(beta)
MAG B550M VECTOR WIFI 7D14.vB42(beta)
B550M PRO-DASH 7C95.v353(beta)
B550M PRO-VDH 7C95v272(beta)
B550M PRO 7D14.v242(beta)
MAG B550 TORPEDO 7C91.vH32(beta)
B550M-A PRO 7C96.v243(beta)
Updated
More info here too :- https://www.reddit.com/r/MSI_Gaming/comments/mmoua9/agesa_1202_bios_for_msi_x570b550_boards/
I'll wait for the final version in case there are issues with the beta versions.
These will be in BETA for the life of these boards and many companies never have a final version now and remains beta and when all seems ok all they do is rename the beta to stable/final.
If you have flashback button on the motherboard or dual BIOS there is no risk. Easy enough to go back to any BIOS you found stable for you. So far the updates have been fine for me on the MSI 570 GodLike.
Do you have a link, or some other info to say why ?
I've been watching the BIOS downloads every week for the last 2-3 months, and the betas do turn into production releases after a while - either unchanged or with changes, you just don't know. Or they are withdrawn. So for my board they aren't beta for life. Once this one becomes final I'll do the flash, which will be the one and only time I think. Enough time will have passed for them to have sorted out Zen3 support, and future releases are unlikely to offer much.
The beta that was listed for the MAG B550M MORTAR WIFI has now had the "beta" designation removed, so I'll take the plunge with this one. It now says simply " Update to ComboAM4PIV2 1.2.0.1 Patch A" though, previously there was also a sentence on improved performance from Zen 3.
Doesn’t look like the new beta with agesa 1.2.0.2 is stable then so it’s been pulled as the 1.2.0.1 was the previous bios.
Was about to update my X570 Tomahawk, on 1.0.0.2 atm looking to replace my 2700X with a 5600X, but seeing it's stable I don't need to flash it right?
I'd update to the lastest non beta especially if you want stuff like curve optimiser and Sam/bar support.
