I just came across this article and it sent a slight chill down my spine. https://www.hardwaretimes.com/msi-cuts-the-warranty-of-its-graphics-cards-to-just-6-months/
When you spend £400 or more on a CPU or a GPU, or any component IMO you would be rightfully expecting the component to last for at least 3 years if not 5, these are expensive devices, they should be high quality and operate reliably for several years.
3 years for the minimum warranty is acceptable to me.
I know this article is for mining cards, and the fact that they are only offering a 6 month warranty for them should tell you how long MSI expect these cards to last mining.
In recent years the push from all sides has been to increase prices while offering less, the 11900K is $540 MSRP, the 10900K which has 2 more cores than the 11900K and is faster was $490, that's a $50 increase in price for less CPU.
AMD have put the prices up on Ryzen 5000 vs Ryzen 3000 while at the same time no longer offering Box Coolers with any of them.
Both AMD and Nvidia's prices for GPU's even for MSRP have ballooned out of control.
My MSI Gaming-X GTX 1070 Quick Silver had a higher quality Shroud and VRM Heat Syncs than my $150 more expensive MSI Gaming-X RTX 2070 Super. the build quality on the MSI GTX 1070 was phenomenal, the build quality on the 2070 Super is average.
When AMD launched their RDNA 2 GPU's they reduced the warranty from 3 years with RDNA 1 to 2 years with RDNA2.
Looking at everything else.
AMD CPU's: still 3 years
Intel CPU's: 3 years
Nvidia GPU's 3 years
So not too concerned right now but its something to keep an eye on because if they conclude we don't care much about how long the warranty is it will fall to 12 months without you even noticing.
And that for expensive components is taking the pee.
The manufactures warranty is how long you should expect the component to last reliably. Minimum.
