Hoping I can get a bit of help on diagnosing the cause of these hard crashes I seem to be getting...
Built first PC in February, played Metro Exodus, PC froze up for a second or two then rebooted itself.
Thought maybe it was because I turned ray tracing on etc. so lowered settings and played a while longer. But then crashed again later in the game.
Since then I have had crashes in multiple games, but sometimes it plays well for a few hours without issue.
I always get a 'Default Radeon WattMan settings has been restored due to unexpected system failure' message when it gets back into Windows, which sounds like a GPU issue, but I havent changed from the default settings.
I was getting drivers from Asus for the GPU, but then downloaded Driver Booster and found there was a much newer Radeon Driver which I didn't have, I DL this (and anything else out of date) but still have issues.
I also changed GPU power connection from 2 PCIE connections on same cable to 2 separate cables.
Bit stumped really... any suggestions?
- Windows 10 Pro
- AMD Ryzen 7 5800X 8-Core Processor
- ASUS TUF GAMING B550-PLUS DDR4 ATX Motherboard
- Corsair RM750x 80+ Gold Fully Modular Power Supply
- Corsair Vengeance LPX Black 32GB (2x16GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Dual Kit
- ASUS Radeon RX 6800 16GB ROG STRIX OC Graphics Car
- Cooler Master MasterAir MA620P RGB CPU Cooler
- WD Blue SN550 2TB M.2 PCIe NVMe SSD/Solid State Drive
- WD Gold 6TB hard Drive SATA 6Gbs
