Monitor UWHD resolution no available on Fury X drivers!
11 Dec 2005
Brighton
Hi guys,
I have installed a Fury X on a Ryzen 5 / B450 mobo and for some reason, my monitor UWHD (3440x1440) resolution is not supported according to windows and Radeon drivers. I can select 2k and 4k but not any ultrawide resolution. I have tried to set a custom resolution in the Radeon drivers but also get the message of not supported. I haven't had the same problem when I had the RX 570 in the system 10 days ago.
Any recommendations?
thanks
Fury cards are only HDMI 1.4, so where limited to what they could do over HDMI.
I remember needing an active DP to HDMI adapter at the time to get it to do 4K @60Hz, with out one it would only do 4K @ 30Hz over HDMI.
DP should be ok.
I have tried the DP port and yes I could get the UWHD resolution but only at 100Mhz, not the 144 I get on my main PC. I guess a limitation of the Fury ports.
Thanks for your help :)
