Hi,
I am currently in the process of an extensive refurbishment project to my soon to be new home and as part of the works, renewing the central heating system throughout the property. I would like to add UFH to the bathroom but would like to know whether any forum member would be able to share their expertise as to whether my proposed system is likely to work or whether I will need to reconfigure to avoid a poor performing heating system. A little information regarding my proposed heating system:
Boiler – Ideal Logic+ 35kw Combi Boiler
Zone Valve 1 – Downstairs Rads
Zone Valve 2 – Upstairs Rads (Inc UFH and towel radiator within the Bathroom)
The UFH will likely be the single zone kit linked below albeit with the included stat omitted/not used within my install and will instead rely on the programmer/smart stat controlling zone valve 2 to control the UFH and the upstairs rads as one.
https://pswtradesuppliers.co.uk/single-room-water-kit/141-10sqm-single-zone-water-kit.html
I would be interested to hear your thoughts on the above as to whether the 2 zones will work or whether I am likely to require a third independent zone solely for the UFH system to be controlled by the thermostat included with the UFH kit.
Thank you in advance for your assistance,
Russ
Russ
