While Intel is a good option especially with the 11400F which I'd recommend for most people looking for a gaming focused build over the 5600X because it's a lot cheaper while still being close with performance the fact you already have a B450 that supports the 5600X via the latest bios offsets any extra cost and makes it the sensible choice.Would a switch to Intel be recommended?
Not at 1080p, is mostly passable at 1440p but not recommended. A R3600 is about right for a 3060 ti IMO.
Sorry mate, was that a response to my question about switching to Intel?
I game at 1440p.
Sorry, was in answer to the original question, didn't see the edits. When it comes to switching to Intel, I'd say the 11400 of 11600k would be a nice upgrade from a 2600, although personally I'd keep to a CPU which would fit in your existing motherboard.
At the moment there are some "B grade" (unboxed or lightly used) 3700x's going for £215, https://www.overclockers.co.uk/b-gr...hz-socket-am4-processor-retail-bg-12d-am.html
I'd personally get one of these or the 5600x you mentioned. Both area great options.
I went from a TN to this IPS monitor and it's been exellent it's also discounted right now.@Shashman would be interested to hear what improvement it makes as I've a similar setup to you with a 2600 and a 3600ti FE. What's your opinion on the monitor you have? I'm looking for a larger 1440 to replace my 24" 1080p TN panel. Wondering if a drop from 144Hz to 75Hz would be that noticeable. Thx
