Consigliere
- 12 Jun 2004
- SW17
The numbers on a toaster is not the heat intensity but the duration.
The numbers on a toaster is not the heat intensity but the duration.![]()
I've never thought of thatI've long been able to wire a plug but it was only when my wife said the blue wire goes bottom left because it starts bl, the brown bottom right because it starts br and what left goes in the middle.
I have no idea if this was deliberately done but it did blown my little mind![]()
.I’m not sure if either of those are historically true, but I like them!I've a couple, obvious when you think about them but I'd never given them much thought;
When you go to an audition and someone says "Break a leg" they are wishing that you end up in a cast.
When someone says "Hold your horses" they are telling you to be stable.
Haha, they’re definitely not trueI've a couple, obvious when you think about them but I'd never given them much thought;
It's more relevant in notation i.e. No one would refer to an F key as E# but it could be written as E# in the context of a key change and then later referred to as natural if it reverts back. Essentially, # means raised by a semi-tone and b means lowered by a semi-tone. The actual note name is irrelevant within notation.
He is a drummer so he doesn't know about notes and stuff and just hits things.
No, I've tested this, the numbers are arbitrary.
There's a Tom Scott video that tests this. The answer is dependent on the toaster and they don't really correlate with each other.
I was just about to post something similar but I realised that he's actually correct. It's not correct to say the numbers are minutes (as Tom Scott showed) but it does relate to "duration"
