- 22 Dec 2020
Is there not a thread somewhere on here that mentions a bent pin on the fan header causing the fan to run at full speed all the time? Might be worth a look.
			Ok! Finally, I found the source of the noise. It's the three frontal fans that together make this rattling sound. I had to spread my fingers a bit awkwardly to stop them three at the same time and it was perfect, nearly silent, so definitely nothing really that internal/core. What could I do to get rid of this problem permanently?
I can't really because I don't go with rgb fans in my builds, although my corsair fans (I've switched to bequiet now) weren't bad and they do do some rgb options. IIRC you do need to make sure the rgb connectors match your setup though.Would you have any recommendations with this vibration dampening (rubber in corners) and RGB? really not familiar with buying fans. 120 mm.
