I can’t help but I’m hoping you can help meIs there a way to reset Big Sur without re-installing it?
I just did a fresh install, but had to create an account to take some images of the MacBook. I need it fresh for when I sell it, but I don't want to waste 30 mins re-formating and installing again, since I'd just done that.
Just need to have the existing account deleted and the setup wizard screen appear.
Thanks for your help, although in my infinite wisdom I still managed to balls it up - all sorted now thankfully.Stick the USB drive in. Start the Mac and hold down 'alt' or 'option'
That will then boot form the external USB drive. From here you get a menu to install Big Sur, or enter Disk Utility etc...
So just go into disk Utility and format your hard drive. I actually deleted all partitions on the drive and formatted it as one. When you install Big Sur it will take care of doing any re-partioning.
Then just exit the Disk Utility and install Big Sur.
I wonder would they try and align it with iOS and IpadOS and make all the next releases 15?I do wonder what's going to happen to the version numbers after Big Sur. With all the OS X iterations going 10.1 through to 10.15 but Big Sur is already on 11.2.3, does that mean the next release will be macOS 12, then macOS 13 after that?
What mouse are you using? I had to install Logitech Options to customise my MX3.I'm setting up a Mac mini and this is the first time I've owned a MacOS machine. Can anyone tell me how to get the forward and back buttons working on my Logitech mouse so they function in the same way as they do in Windows? I've searched for answers but haven't come up with anything yet.
EDIT - I'm also finding the standard desktop fonts look less well defined at 34" UW 1440p than they do on Win10. Is there anything I can do about that? I found a scaling option but it just makes everything massive while still making the monitor appear as if it's at the wrong resolution.
In fact you don't even need to customise it as such. The software will install a profile for Safari and that will set up the forward/back buttons.
As for the fonts on your monitor I have unfortunately never found a solution to this - any 1440p monitor I have used is the exact same.
I was going to mention earlier but decided not to however you could experiment with disabling font smoothing within Big Sur. Objectively it probably won’t make a massive difference but subjectively some people say it looks better and others say it’s worse. You could give at a go and see what you think yourself.And the fonts thing is a bit of a bummer. My son is currently using my old 40" 4k monitor and I tested the Mac mini with that and it looked good in terms of fine smoothness, but I can't go back to a 40" screen and it's also too harsh on my eyes. I have to ask myself if it's worth stumping up for an IPS 4k monitor or send the Mac mini back.
).It's more than likely the installer dmg mounted as a disk image. Usually the OS will ask if you want to eject it after application install. Right click on it and eject if it's a disk image.A shame it leaves an icon on the desktop. I have no idea what an icon on the MacOS desktop signifies.
Yeah as you say it's just the fonts. All other elements such as app icons look really nice on the 1440p display.Thanks for the suggestion - I tried setting font smoothing to zero and it hasn't done much. Reading this forum it's like my 1440p monitor is running in 1080p (and the display resolution is definitely correct).
Pretty sure there is a keyboard layout you can select in settings.What’s the easiest way to permanently swap the mapping of the @ and “ keys on MacOS so they’re in the same place as on Windows?
I’d prefer it if I didn’t have to just get used to it. I use “ a lot and accessing it involves an uncomfortable contortion of my wrist to type it and I often miss the key.
It’s labelled British - PC.
