New build (5950X)
18 Oct 2011
Hey, looking to revamp my build in the next few months after around 6-7years with my current. Going more high end than i have previously as i will be keeping the build for the same or more years. Always had a lot of issues with motherboards and overclocking so willing to spend a bit more on it than i normally have.
I listed two motherborads as i am torn between both at the moment, any suggestions or pointers on memory etc would be appreciated.
My basket at Overclockers UK:
Total: £3,418.57 (includes shipping: £14.70)
https://www.overclockers.co.uk/raij...case-black-with-tempered-glass-ca-04q-rt.html
Also, much better warranty !
https://www.overclockers.co.uk/giga...4-x570-chipset-atx-motherboard-mb-57t-gi.html
do their own AIO
https://www.overclockers.co.uk/giga...uid-aio-performance-cpu-cooler-hs-00c-gi.html
as above, not doing workloads then 5800x and b550 will do!
and 32gb of ram - save a lot!
https://www.overclockers.co.uk/patr...dual-channel-kit-pvs432g360c8k-my-107-pa.html
What will the PC be used for?
Gaming / Streaming, i always run an mmo in the background while playing a fps or i used to pc cannot handle it as well now days. Also normally have a minecraft server up for kids. Basically will be doing everything i just mention at the same time, i know it is still overkill so to speak but that is not a large concern of mine as the amount of years i will have the system.
850W would be enough for this system? ATM with a 980TI but will be a 3080 or 6800XT in the future? Cheers.
Motherboards seem crazy expensive, though they are good. Not sure when you are considering buying but I believe the X570S revision boards are potentially out soon.
