I think these will need machine polishing out. I've taken them out a bit by hand, but it's hard work lol
Extremely impressed with the gloss on my M4!
I bought this and it was fantastic:
https://www.amazon.co.uk/gp/product/B07N9C7MGG/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Any recommendation on a decent tyre shine please?
And also this which was also really good:
https://www.amazon.co.uk/gp/product/B003LVZE2E/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
The autoglym high performance tyre gel reviews well, and I've seen some good praise recently for the Garage Therapy tyre serum.
Yeah basically. It's a really high quality brush as far as I'm concerned. It did look a bit odd but performs great.Are those reviews for the muc off brush because they've misunderstood the product? Seems to be a lot of complaints that the bristles look worn/frayed at the end but I'm guessing that's by design to make the brush soft?
That looks unreal and love the colour, I imagine it’s a special colour for the M4? Not familiar with BMW’s.
Absolutely *do not* use those type of wheel brushes. Cleaning my old car I didn't realise the little rubber protector had come off the tip (matron!) and it exposed the twisted metal core which the bristles attached to. It scratched the life out of the wheels which I had to get repainted.seen these, but not sure
https://www.amazon.co.uk/dp/B07W5NZ...olid=15FRFL8T36IHR&psc=1&ref_=lv_ov_lig_dp_it
The Meg's brush is great for general cleaning, but you might also need to grab a smaller version of the same style as it may not fit between the wheel and caliper. I use the small one from this set for that:
https://www.amazon.co.uk/DUMI-D8D12...ing+brush&qid=1619776729&s=automotive&sr=1-21
This is a Ka I helped work on last year. APC/TFR was left on it to dry and needed polishing out with a machine in the end.
I swear by the AutoGlym Bumper Care gel.Any recommendations for something to bring back the dull external black plastic?
