i wouldnt waste my warranty for the sake of running it cooler if there was any chance it will break in a few years and be rejected, you dont think they will bother to look but i doubt it costs a lot to take a card to pieces and then they save the money on replacement by declining your rma
its the reason i have no interest in a founders model cause its a hairdrying egg fryer
As I said, when I was younger, I wouldn't think twice about changing a GPUs stock cooler. Even reverted a card to its stock cooler for RMA.
Yet now, I am hesitant.
Age has nothing to do with it. Stock availability is the issue. Saying that someone in another thread sent a 3080FE back and I think it took less than 14 days and it went to Hong Kong if I recall.
Its down to personal preference whether you change them but I dont think I need to plus my warranty is safely intact 100%.
Thanks for detailed post! Is that a FE card you modded?
In the video on the article I linked above, the guy does not appear to change the core thermal paste at all. I wasnt sure if thats a good idea?
I went ahead and replaced the pads this morning (backside only). Was quick and easy! the hardest part was trying to pull off one of the magnetic covers as none of my tapes were strong enough lol.
Temps have reduced by 10C. I am now happy for it to mine through the warmer days. Saying that another couple month and I would have paid off the card so even if it were to break down technically I would not be out off pocket of RMA was declined.
Which pads did you use?
I just ordered 5x packets of the GELID Xtreme for £40 delivered. I plan to just do the backside to begin with and see how I go. But have more than enough to do the front, and possibly re-do them if I mess anything up.
As said, I dont mine and just want the thing silent when gaming.
As long as I can get the temp below 100, ill be fine. It seems that once the temp hits 102, the fans go crazy.
So a 10 degree drop would be perfect. Take me to low 90s, which should keep it nice and quiet![]()
I used the: Thermalright Thermal Pad 12.8 W/mK, 85x45x1.5mm
Bought 2 for almost £30, but that was delivered next day. Could have probably got it a lot cheaper from China?
Prior to this I had my temps hitting 100c constant. But that was with a heatsink and fan sitting on top of the card. Now I have the new pads and the heatsink and fan still on top. Running all day today and temp stayed pretty much on 90c, went up to 92 briefly when my mrs decide to put the fan heater on next to the pc :/
I run the card on 75% power as I don't like to keep my fan running too high. Currently they are fan1 65%/fan2 50%
Ok sounds like a great result.
How are the temps when you game ? Do you put the card to stock clocks/fan curve then?
I have read several times that 2 packs were enough.![]()
I haven't really noticed very high temps whilst gaming to be honest, I only played FSM2021 fully maxed out so far and the other games I play do not really push the card very far.
This.
https://www.reddit.com/r/nvidia/comments/n1f4sr/taming_the_3090_fe_vram_temps_part_2_gelid/
1.5mm Gelid Extreme on GPU Core side
1.5mm Gelid Extreme on backplate if using stock shunts. 2.0mm Gelid Extreme if using soldered stacked shunt mod (clearance issues).
Thermal Paste: Thermalright TFX, Thermalright TF8, Kryonaut Extreme, Coolermaster Gel Maker Nano, Arctic MX-5.
It's a risk but if you plan on keeping the card long term probably worth it in my opinion. It could be the difference between it dying after 3 years or not
How exactly do you know that?
The word "could" was used....
