- 22 Feb 2014
I am pondering over what to do lighting wise in my workshop.
Currently have a twin 6ft fitting with plastic reflective louvres in which directs the light downwards more than an open fitting. I have just replaced the 2 tubes with fluorescents as a test and it is much brighter.
then also have a 5ft uncovered fitting.
I tried an LED tube in the 5ft fitting and the light "quality" wasn't as good, it seemed as bright yet the room wasn't lit up as well.
What have you guys used ?
I think I want 2 x dual 6ft fittings to replace both of these, and I would get a fitting with a diffuser instead of a closed louvre one, just to let out the light to the sides a bit more.
Also any decent LED tubes, i don't mind buying LED but the light has to be at least as good as a "normal" bulb, which are being phased out so getting harder and harder to come by.
