Images of items I have purchased (except trainers)
Man of Honour
29 Jun 2004
Oxfordshire
Treat myself to a proper sim rig setup. Unfortunately the monitor stand bolts were knackered so had to order some more for tomorrow before I can have the monitor attached to the cockpit. Having to make do for now
25 Jan 2021
Speaking of large appliances, a new fridge freezer arrived today.
Haier HB18FGSAAA American Fridge Freezer - Titanium Glass
Great choice, we have slightly older, stainless steel model for over 2y and it's absolutely brilliant.
Performance, usability, capacity - can't beat it in that size range.
Man of Honour
20 Sep 2006
My Steel Series Actis Pro met a premature death yesterday, all audio in the right channel stopped working (even when the receiver was turned off). A bit of Google Fu suggests that there is a cable which can come loose so I opened a support case and they're authorised a replacement. Since I use them for work calls (which they are excellent for) I needed a fast temporary replacement as I don't really have much else suitable at home. I've had my eye on AirPods Max for a while and having recently received a decent bonus from work (and some luck with Crypto currency) I thought I'd treat myself and relegate my QC35 II to spares or for use by the mrs.
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
How do you find the purse/handbag case?
Man of Honour
23 Mar 2011
West Side
Whoops. yes I forgot to photograph that. It was also the one you recommended, the arctic jobby. Jesus Christ that thing's huge.
Will keep that 5800x cool could have gone for the single fan version but recommended the extra fan version for added bling. :D
Look forward to some pics when up and running , enjoy.
