Garden hose for pressure washer
7 Apr 2009
Greenock, Scotland
Hello. Im looking for decent quality garden hose that is up to the job of pressure washing and reasonably kink free and preferably one that comes on a real and above 30m. I know good hoses are pretty expensive but my max budget is abot £40. Thanks
That sounds about right
Just realised you're in Scotland so not much help!
Personally after getting one where the hose is on display on the wheel, I'd get one that conceals it in a box unit, just easier to wind in.
Are you sure it is?
I got an extension to the pressure hose for my last pressure washer. It was an utter pain in the backside. Because of the necessary construction, it just isn't as flexible as normal hose, and it constantly catches itself in loops and gets caught on things. I used to spend a lot of time swearing at it.
Are you sure it is?
That just means you got a rubbish one.
https://www.directhoses.net/
I've got a 25m one on mine, pressure washer stays in the garage and I can do the whole front and back gardens and car on the street without moving it. Lovely and flexible as well.
Yes they're more expensive but save up for a bit.
