Hi there,
i have had an issue over the last month or so that I thought was related to my move from windows 10 to Linux mint whereby my monitor would switch itself off saying 'monitor going to sleep'- when playing games, largely football manager, prey, dark souls 3. I spent ages trying to fix, and then when using Win10 (i have a dual boot machine) it happened then also, so its not just Linux related.
My specs
I have tried different cables (DVI, HDMI and displayport), and the issue happens with all. Other than this issue the monitor has been trouble free for a decade. I don't think its the monitor.
From a ram point of view, I have pulled it, and tried in a different dual combination. I have run windows memory diagnostic tool and also memtest and it always passes. I have tried the XMP settings on and off, manually adding, running lower speeds, timings etc. With the graphics card in, I always get the problem. So probably not memory related but I am not sure.
The graphics card is ancient and I have been trying to buy a 3080 for ages but not managed it for obvious reasons, hence playing the less demanding games. I don't have another graphics card to swap out for it unfortunately. It is not overclocked. I have pulled it, removed the stock cooler and re-applied thermal compound. The tempretures always look fine. Currently I am using the integrated graphics, and I have never had the issue when doing so. Perhaps the GPU is the most likely culprit? A visual inspection shows nothing obvious on the card.
Mobo - seems ok, no other errors. Not sure what to check. I tried running overclocked for a while without the graphics card to see what would happen. I ran prime95 for hours with no issue. This was the case with no overclock and overclocked. So I am thinking not motherboard related for now.
The PSU is also tricky to check, I get no other shut-downs, I have looked at the voltage in the bios and there are no great variations just minor ones I have observed in all psu's across the years. I am thinking its not PSU related for now.
I have been able to run football manager and lots of other things with the integrated graphics (with the GPU pulled out) and I have had no issue. I think a key point is, I have not observed a 'crash' when not using the GPU. The opposite view could be the machine is not being stressed enough I suppose.
So, I am a bit stuck, something is not happy. Can anyone suggest anything to narrow the issue down? I think I have gone a bit 'blind' by trying so many different things.
Thanks for reading, apologies for the long post! Thanks.
My specs
- Intel Core i7-9700k
- Samsung 970 Pro 1TB NVMe
- Gigabyte Z390 Aorus Ultra Intel Z390 DD4 (running f10h bios)
- Gigabyte Aorus RGB 2x8BG DDR4 PC4-25600C16 3200MHz
- Corsair RMx 750 80 plus Gold Modular PSU
- Corsair Hyrdro H 115iPRO RGH Liquid cooler
- HP2475w monitor
- Palit Geforce Jetstream 970.
