MSI MEG Unify x570 or MSI Tomahawk x570
6 May 2021
I can see Tomahawk is super popular. However, I can see the MSI Unify also received a lot of positive reviews. Is Unify better than Tomahawk other than the price, extra M.2, and Extra PCIe slot. Paying an extra £70 is not a problem. Just confused about which one to go with.
Can Tomahawk handle future Graphics card upgrades like for 4 years and other minor upgrades? Or paying the extra few quids and upgrade to Unify for future proof.
AMD R9 5900x
32GB 3600Mhz RAM
RTX 3090
850W Platinum PSU
Any Specific reason? Does it perform better than MSI unify? Budget is not an issue, I am just looking for the best within £200 - £300
The Tomahawk has the better VRM, but both would easily handle a 5950X. If the Tomahawk has the features you want then it is fine. There are also a lot of good B550 boards as well i.e MSI B550 Gaming Edge Wifi/B550 Tomahawk, Asus B550-F or Gigabyte B550 Aorus Pro that will handle that cpu with ease. You don't really need to spend that much for a board to get something good.
The RTX 3090 is also poor value for money if your main aim is gaming. An RTX 3080 would be a better option. If you need the extra Vram for things like editing then fair enough.
They're extremely similar. Only real difference is the extra M2 and PCIE slot.
I'd save the money personally.
The RTX 3090 is also a poor value for money if your main aim is gaming. An RTX 3080 would be a better option. If you need the extra Vram for things like editing then fair enough.
I only game and code. Then I guess I will choose RTX3080. Also, its just been 20mins that I placed the order for MSI Unify. However, I can always exchange it for the Tomahawk..Thanks for the details I will get the Tomahawk
The B550 Gaming Edge is £60 cheaper than the X570 Tomahawk and you still get Wifi 6. It has a solid VRM so no issue even with a 5950X.
My basket at Overclockers UK:
Total: £170.45 (includes shipping: £10.50)
