Yeah, install it and depending on the condition you'll get about £200 for it.
When you hand it in to get tested make sure you do it early doors - as reasonable close to opening time as you can get. Then go have a few pints and come back. It takes them ages to test it.
Tried this and various other combos but get a flashing folder icon with a massive question mark. Ethernet is plugged in. It means a USB drive recovery is required. I'm looking for an easy way to create one in windows without jump through 5 million hoops.
CeX was a no go. They require working OS. Also, they didn't have my exact model on the website so I know from experience they won't accept it.
I ended up getting Catalina onto a USB drive and installing it onto the 3TB Fusion drive. Check it out if you're interested. https://www.ebay.co.uk/itm/133761235725
