Dropped car of this morning, spotted @paradigm also, hope your well mate.
Mechanic says the engine noise is tappets and he says in his oppinion they are pretty quiet (car is much quieter now since I did lash), he said I did the correct thing only making 1/4 turn on the rocker arms.
He is gonna give the car a thorough checking over and fit the new steering pump, sort the alignment and centre the steering box/wheel.
He said if engine gets noisier then he will do a proper cold lash adjustment and check all the parts for wear and replace if necessary.
Yep, we’re good, thanks! Car looks superb, can’t wait for things to start to return to normal to get a run out in it!
