 - 10 Feb 2021
Hi,
Wanted to see if anyone tried to put a fan on top of the backplate of the 3090FE where the memory modules sit without putting heatsinks on top (like this: https://imgur.com/a/bG63inK). On my card, they got hot to the touch, and my options that aren't repadding or going on water are limited since I also rock a big CPU cooler:
https://imgur.com/a/FpYS649
I mounted a extra fan I had lying around vertically which helped drop temps 2-4C depending on game, but I'm wondering if I just jam a super slim fan between the CPU cooler and GPU (I think Noctua's 14 or 15mm fans may fit, definitely not the 25mm "normal sized" fans), if that will reduce temps a bit better.
I know this works on some AIB cards since the backplate is perforated and has holes, so pointing a fan downward on the backplate have gotten some people great results, but not sure on the FE cards. Anyone try this?
 Though I wonder if you CPU cooler has any impact being so close....
