OK so budget is around £23k, 2017 or newer, max 40k ish miles.
Looking at E220d and 520d (G31) at the moment.
Leaning towards the Merc at the moment as they seem to be much more plentiful in budget and look pretty nice inside as long as you get the widescreen displays which seem to be a must (you can’t even get CarPlay unless you spec the COMAND system, which 80% of cars don’t seem to have
The 5 series seems to be a bit more expensive but the standard spec seems to be better with the big nav screen as default. SE is in budget but M Sport is right at the top end. Would I be missing out on much if I went SE?
Has anyone driven one or both? Any thoughts?
Ps. Ruled out the Skoda Superb before anyone suggests one!
) The 5 series seems to be a bit more expensive but the standard spec seems to be better with the big nav screen as default. SE is in budget but M Sport is right at the top end. Would I be missing out on much if I went SE?
