Best Android for under £200 - Poco X3 Pro?
12 Dec 2005
I'd like to get an android phone for under £200. The main one I see at the moment is the Poco X3 Pro for about £200, is this about the best you can get for the money? Do any of you guys have one?
Recently bought Mrs Monkey the 256GB version of the phone, what would you like to know?
How smooth does it feel under regular use, such as web browsing, emails etc. Does it feel quick to use? I know some budget phones can lag and be quite slow
Initially I used just after using a new OnePlus 8 Pro and was left a little disappointed, it appeared to lag a little in places, but using for a few hours straight without any other phone it seemed how I expected it to be, quick in most places, a little lag on occasion, but nothing major and enjoyable to use, nice big screen, loud dual speakers etc..
I had to remind myself it only cost £250 for an 8GB/256GB phone with top specs. It should be faster/smoother for the specs but it's likely down to software which updates can improve on.
It's definitely not slow, and for the money it's the by far the best I've used. I was really tempted to get one myself (or the bigger brother the F3 for £350).
The only thing stopping me getting the same model myself is the max brightness, I generally like really bright displays, but for most uses its plenty bright.
aa
Thanks for that
Yeah, definitely seems like you can't get anything similar for the money. It's currently £200 for the 128GB version, might be worth a buy
