Linux program to see what directories are taking up all the space?
1 Nov 2007
England
I've used programs like this before on Windows 10 and wondered what programs are recommended to do this on Linux? I'm using OpenSUSE Tumbleweed and KDE on the btrfs file system, if that matters. I want to figure out why my install is 38GB in size, which seems somewhat excessive.
Thanks for any help.
ncdu its wonderful
its an interactive Folder explorer its only 96K too. you can use ncdu -x to lock to folder/mount your inside
disk usage analyser comes pre installed on POP OS! new beta at least and i had no idea, i found it thanks to the above link and its really good.
du -sh /* will be a lot quicker than faffing about with any program
ncdu will take the same amount of time as du to do the initial scan.
If anything ncdu is quicker as the provided UI allows you to traverse the file system and drill down through directories without having to scan again.
