Permabanned
- 12 Jan 2021
so the mondeo has run out of fuel a few mins after i started it, will get some more fuel tomorrow are these a ball ache to get going again.
Most diesels are self priming now, or shut off the engine before the engine is fully starved of fuel so you don't have to reprime the fuel line.
Add fuel (you may need the funnel thing if it's an Ford easy fuel cap), switch ignition on for 10 seconds, THEN try to start like normal.
The Mk4 2.0 TDCI doesn't self prime (you have to prime it even after a fuel filter change), not sure about the Mk4.5, but hopefully it shuts off before the lines run dry.
how do you prime it just incase i have too ?
Not done it myself, I have a fuel filter & tools sat waiting to be fitted but I fear I'll screw it up
There's a schrader valve in the engine bay, on the MK4 it's on the right hand side of the rocker cover with a grey cap. Easiest way I've seen online is people using a tyre valve extension (like a HGV driver would use to access the inner wheels on a dual wheel axle) with the actual valve removed then one of those syphone tubes with a priming bulb in the middle attached to it. Just pump it through till there's no bubbles and you're good to go. It can need a good pump through but that's when you've opened up the system to add a new filter, might be less work if it's not quite run the lines dry for you.
