8Packs AMD 6800XT overview... and abit of overclocking ;-)
OcUK Staff
20 Feb 2012
John Smiths Stadium
I was very lucky to recieve a sample AMD Redeon 6800Xt directly from AMD to evaluate. I have for awhile now offered Threadripper as the default option in my Supernova rig and as an option in my Polaris as these CPUs are by far the best brute force multi thread units available right now. I have also offered Threadripper and Ryzen upgrade bundles aimed at both brute force and gaming.
After testing Ryzen 9 59xx X cpus I decided this new King of gaming needed its own 8Pack system and with the new AMD gpu coming what better time to pull all the full AMD kit out of the locker room...Providing the GPU was good enough to be in an 8Pack system ofcourse... and that was the big question I wanted to answer with this testing.
My first impressions of the card once unpacked was that the cooler was very substancial and certainly more an AIB offfering than an AMD reference design. I was hoping for good enough cooling without mounting a waterblock (yet) which allowed for initial evaluation of the performance.
My test rig for all this benching / gaming was:
5950X OC to all cores 4.7 or PBO boost
ROG Crosshair Impact X570 MB
16gb 8Pack RAM running 3800mhz C16
Windows 10 64 with latest prerelease AMD drivers.
Here are a couple of pics of the test rig.
I did not do much stock clock testing as thats not really my bag, I ofcourse did run stock though just to check the card was running as expected and had arrived without any damage. The first thing I noticed was the cooler was indeed very solid and quiet. It kept the loaded temps well in check so hoped this would give some solid overclocking headroom.
I tried all tests with and without AMD Smart Cache enabled and saw an increase of between 1%and 6% on the overall score / FPS with it enabled..So again I want the highest scoress so I run with... For me Rage Mode / AUTO OC (probably because of the early nature of the driver) was offering me very little in extra performance. With this in mind I wanted to maximise the card through manual OC.
The settings I used for the results I gained where all gaming stable. I maxed out the Power limit ran 105% on memory with 101% minimum clock and 111% maximum clock frequency on the core. This resulted in a boost peak of around 2..6ghz!! a raw clock figure only ever possible with sub ambient cooling on any previous series flagship card by any vendor. All these tests where also done with a stock fan profile very much repeatable by the avaerage gamer.
Below are screens from some of my resukts which I will comment on next:
3D mark Firestrike
3D mark Firstrike Xtreme
3D mark Firestrike Ultra 4k
3D mark Time Spy DX12
3D mark Time Spy 4K
Heaven Valley and Heaven 4.0 both at 1080p with maximum settings
and finally Superposition
1080P medium and 4K optimed settings..
So what conclusions could I draw from these early benches.. The 6800XT is an amazing card in Firestrike at all resolutions. Firestrike is a DX11 bench and in this DX11 workload the 6800XT was beating not the 3080 overclocked but the 3090 overclocked by quite some margin. This for me also translated into gaming performance running Battlefield 5 in DX11 and saw the same result.
In all my other synthetic testing shown above this overclocked 6800XT was trading blows with and often beating a 3080 overclocked on the same platform. I checked my scores against the best in these benches published on this forum by our end users and saw very similar.
I then simply played the games I am enjoying right now so Warzone, Dirt 5 and Forza Horizon 4 withmy typical settings which is almost maxed out , but not quite ..... as I like above 100fps and recorded the results. In Warzone and Dirt 5 the 6800Xt was for me around 5% faster than the 3080 when both are Overclocked and in Forza the 3080 was around 2% faster than the 6800XT.
What could I conclude from this quick and dirty testing was that AMD have made a very good card and at different workloads able to trade blows with and even beat the previous best. I cant wait to try 6900XT as from this the 6800XT is definately 8Pack approved!!!
I also got a chance to try the EK Block for this card and saw further OC headroom unlocked with an extra 6% on GPU and an extra 2% available stable on the memory. This again offered even more performance with max boost now close to 2.65ghz. The EK Block kept loaded temps around the 50C mark with a 360 rad attached and 1400rpm fans.. SO maybe if you want to run the fans at a less than favourable noise level more OC could be unlocked on air cooling!!! Thats something I did not try but certainly worth experimenting with if your gaming with headphones on or just going for that benchmark score.......
Any questions you have about this card let me know below and watch our channels for the 8Pack AMD powered system I use this card in.......
Speaking of EK blocks (seeing as the reference card seems to be a very shot run) do we know ahead of time if that block will fit any of the AIB cards ?
From the official pictures I have seen online of the sapphire / power colour / MSI they all seem to be built on a custom PCB (at least removal of the USB-C port or changing of the 8pin connectors.
Was hoping this round to get a water block and card ASAP .... maybe not :D
@8 Pack
Good to know, ive had a 5950x on order since release and various other bits of equipment that have been out of stock for weeks on end. In general we know the asus dark mobo is coming soon but do you know if new flagships are on the way (not after specifics, but a yes or no) as I legit don't know if the aorus extreme on my order will ever be back in stock, same for the msi godlike or the formula boards. As such, will you have new top of the line flagship combos coming anytime soon?
I don't know of any new flagship boards other than Dark. Which I will use in the new system and had a while now for testing.
Oh dear, as the dark looks crap for a showcase build :( (imho)
Well I look forward to the combos being available I guess if the other flagships never turn up again.
Nice one @8 Pack :)
Is 5950X the ultimate or i9 @ 5.1ghz all core?
Its actually close at higher intel clocks with tuned cache like 5.2ghz and 4.8 cache. But with AMD gpu, amd cpu makes absolutely sense... Even with nvidia I can't argue intels case unless you have the absolute best silicon in OC terms.
Looks very solid in this build... But again aesthetics totally own opinion... As you can see from my testing here impact is really my favourite x570 board.
Yea, well will keep an eye out if nothing else materialises, may just have to accept the crap aesthetics to get a system built this side of 2022 :D Thanks buddy.
Honestly, an amazing card. I was lucky enough to have owned both a 3080 and 6800xt, with a ryzen 5900x and I gotta say, the 6800xt destroys the 3080 at 1440p. First time going amd gpu wise and I don't think I'll go back. Even the latency feels quicker and smoother, and freesync seems to work better with my LG Gl850 than gsync did.
I got a timespy score of 18664 with an MSI air cooled card!
I've not seen any reviews that support your 'findings'. If anything the two cards averaged over multiple games at 1440p give similar results. Some you win some you lose. The 3080 can pull ahead slightly at 4k, but only a small percentage.
The only consistent place one actually does destroy the other is if you want to use Ray Tracing. And we all know what happens then ;)
Hardware Unboxed did a good review of these two gpu's using a Ryzen 5950x if you're interested.
I like the cut of your jib fine sir. I know many users of both cards who came to similar conclusions.
Not to say the 3080 is a bad card though. Despite that paltry VRAM buffer.
what a strange thread to resurrect could you have not commented in the owners thread ?
