My MSI mobo came with a Wifi/Bluetooth signal booster... is it possible to buy a more powerful one?
Caporegime
8 Sep 2005
Utopia
Hi guys. As per title, my MSI mobo came with a Wifi/Bluetooth signal booster, that has two screw-on wires that connect to two sockets on the back of the mobo in order to boost signal strength and range of the integrated Wifi/Bluetooth. Similar to this:
Does anyone please know if it is possible to buy a more powerful 3rd party one with a longer cable (assuming the connections are generic) and have any recommendations?
Many thanks. :)
Not heard of better ariels but you need to extend/boost the signal from the router . Powerline adapters are one option wifi boosters, etc If thats is the problem.
Thanks mate but I need a boost directly from the antennae motherboard to primarily boost the internal signals coming from the motherboard Bluetooth chip. :) I did some research and something like this may do the job... https://www.amazon.co.uk/Ziyituod-F...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
