The clocks on your gpu will have bumped up a little bit in order to run multiple displays. It used to get locked to max clocks, the newer the gpu the less it clocks up as they are better at driving multi monitors /the clock rate bugs are a bit more fixed.
I would have thought it should be on high 2d clocks rather than full on 3d clocks on a 20 series. It's not really an issue beyond it uses a few more watts. But it is a known issue. You may be able to force lower power states via afterburner/rivatuner, or changing the multi monitor/power settings in nv control panel.
If it bothers you enough, have a nasty around with different settings though, I think afterburner can auto apply profiles for 2d vs 3d nowadays, maybe just create a profile with the power slider at minimum?
Nah, it's not actually under load or anything, no degradation or anything etc. it's just not down clocking/setting power state to low to save idle power like we all think it should be.thanks, i will look into it. It doesnt really bother me, the only concern I have is if can damage somehow the GPU if running like it is all the time?
If not, then im fine with it atm.
I just finished setting up my second monitor, but I have noticed in AfterBurner that my temps have increased from around 28c to 35c
roll back the drivers to see if fixes![]()
Yes if it's a Nvidia GPU.
Also check your refresh rates on the monitors. I found recently that if you have monitors at different refresh rates, the GPU will not idle at as low a frequency as it otherwise would. On my 1080ti, it was idling at ~1100MHz when I had one monitor at 144Hz, when they were all at 60Hz the idle frequency dropped to ~300MHz Obviously the higher idle frequency will cause an increase in temperature.
Yeah, its a 2080 Super.
maybe but thats not it, i used to run 2 monitors and unplugging the second from the card dropped the temps 5cit's getting warmer now so your room temp will have gone up?
Ahh well, there you go, the mew monitor is only 60hz against my 144hz main monitor. hmm..
now its nice and fluid..
