- 27 Jan 2003
- Chesterfield, UK
When I set my 5950x to stock, voltage at single core max load = 1.45v, voltage at multi core max load roughly 1v +-0.05v
So that's the stock behavior. If I enable PBO, single core voltage is exactly the same, multi core max load voltage jumps up to 1.29v
So as far as I'm concerned 1.29v is safe for overclocking because when I give the CPU free reign to boost as high as it wants to it will go up to 1.29v
Highest I've tested for all core manual overclocking is 1.25v, I reached 4.6ghz all core with that
I would agree with that.
I look at my loop delta. I’m am trying to keep it low while keeping the performance high. Makes it an efficient and silent system.
just have to find out if its stable which will take some time currently getting on cinebench r20 multi 86k and 640 single which I dont think is to shabby with temps not exceeding 60c
