Evening all.
Looking for advice on how to proceed with a fault developed by my Golf. Its a Golf TSI SE Nav 1.4, MK7 (17 plate) with bang on 20,000 miles on the clock.
About 3-4 weeks ago I was turning left around a tight corner in a retail park and accidentally bumped into the kerb. Wasnt going more than 5mph. The infotainment system immediately cut out, and after 2-3 periods of static/garbled audio it has been completely dead and unresponsive. I assumed that I had knocked a connection loose, and didnt really prioritise fixing it given i barely drive nowadays. Theres no power to the USB charger, either. The only signs of life are the fans spinning up and down on the glovebox unit.
Fast forward 2-3 weeks i've finally started to investigate. I've removed the glovebox unit and the screen unit and visually inspected the cables connected to each but they all appear to be seated correctly. I've given each one a push just to be doubly sure they are connected.
I took it a Volkswagen dealership today who after a day with it have determined I need the entire glovebox unit replacing, part number "J794-5F", and the entire cost will be £2.4K (!!).
I've complained bitterly to Volkswagen customer care who have raised a case for me and will investigate. Has anyone ever had similar issues? Any tips on how to proceed without this costing me an arm and a leg?
TIA
TIA
