- 2 Jul 2019
Made a similar thread below about how my new GPU causing some issues. Right now i'm just trying to get into bios.
https://forums.overclockers.co.uk/threads/no-signal-on-monitor-s-from-gpu-s-help-input-plz.18929446/
Currently computer skips splash screen and monitor only comes to life when windows in logging in. Pressing Del on boot gives no signal from monitor. Tried different monitors, cables, etc as stated in other thread.
I've tried holding Shift when restarting and selecting UEFI mode. No signal again and forced to turn off via power button.
If i switch to my old GPU, no issues with splash screen and BIOS.
Updated drivers yesterday, along with flashing MB to latest.
Any ideas? Thanks
Spec:
New monitor: Gigabyte G32QC
Old monitor: Samsung F390
New 2nd hand GPU: Asus Dual rx580 4gb
Old GPU: Gigabyte Windforce OC rx460 2gb (not direct PSU powered)
PSU: Seasonic Focus Gold 650w (probably 6 months old now)
Motherboard: MSI B550 Mortar Max
CPU: Ryzen 3600
Latest Radeon drivers, WIn 10, latest MB bios. Latest firmware on Gigabyte monitor.
(update) ...with some questions
After some digging I suspect this new 2nd hand GPU was used for mining. I've only got MSI Afterburner on my system atm so unsure how reliable that is. But it says the core clock is 1162mhz and mem at 2000mhz. Given the core clock is lower than my rx460 seems a little odd, and the stats fit with what people use for mining on the card.
I can't see a dual bios switch (unless i'm blind) on the card. Can't see anything in the manual, about well anything outside of installing a vga driver. I can't see anything online about the card having a dual bios. And i'm definitely not hunting down the original bios to flash from unofficial sources.
Stuck my old card in and changed to UEFI mode from CSM, and went through various settings but can't see anything else. Just guessing here really as i'm all out of ideas now.
(update)
So i ran a windows ram check just because why not, no screen showed up for this, but the computer was back on desktop by the time i made and ate my dinner. So no idea if it finished and rebooted or what.
(edit)
Just flashed the card in the end after taking it apart and matching up the correct bios, used the techpowerup website for a guide. Issues have now be resolved.
Any ideas? Thanks
Spec:
CPU: Ryzen 3600
(update)
(edit)
